Excalidraw Mastery: Building Your Toolset
Excalidraw Mastery
Learn Obsidian + Excalidraw with confidence
Excalidraw Mastery is a dedicated membership inside the Sketch Your Mind Community.
For people who want to get real value from Obsidian Excalidraw.
You get structured guidance, practical tutorials, live support, and a focused member space.
What You Get
  • Getting Started with Excalidraw
  • MindMap Builder
  • Monthly live Zoom Q&A sessions
  • Growing tutorial library
  • Member community
  • Real-time member chat
Why It Matters
Excalidraw can become your visual thinking workspace.
Notes, sketches, PDFs, ideas, links, and systems can live together.
Excalidraw Mastery helps you get there faster.
Who This Is For
  • Obsidian users who want to master Excalidraw
  • Existing users who want better workflows
  • People who prefer learning from the creator of the plugin
Included Course 1: Getting Started with Excalidraw
Total Runtime: ~2 hours 40 minutes
This foundational course helps you go from blank vault to a confident visual system.
Lesson Duration Overview
01: Obsidian UI Basics 11:35 Tabs, ribbon menu, command palette
02: Links and Tags 06:01 Wiki-links and ghost notes
03: Note & Block Embeds 06:32 Reuse specific paragraphs across notes
04: Media & Backlinks 11:39 YouTube, images, relationships
05: Folders & Properties 12:05 Metadata and attachments
06: Excalidraw UI & Setup 13:54 Installation and UI modes
07: Embedding Drawings 07:35 Create drawings inside notes
08: Image Management 14:45 Layering and future-proofing assets
09: PDF & File Embeds 05:13 Interactive readers and annotation
10: Nesting & Marker Frames 12:46 Reusable LEGO blocks
11: Link Config & Modifiers 06:58 Navigation behaviors
12: Two-Sided Notes 11:59 Front visual / back markdown
13: Markdown Cards 10:24 Bidirectional text workflows
14: Automating with Scripts 11:43 Save time with automation
15: AI Coding & Community 11:48 Use AI to extend workflows
Included Course 2: MindMap Builder
Total Runtime: 4 hours 46 minutes incl. live session recordings
Turn Excalidraw into a keyboard-driven mind mapping system.
With MindMap Builder you can:
  • Build maps using your keyboard
  • Convert Markdown into visual structure
  • Turn reading into connected knowledge
  • Organize complex ideas with folding, grouping, and layouts
Setup & Fundamentals
  • Installation — 6:46
  • Getting Started — 7:48
  • Layouts & Hotkeys — 23:29
Advanced Content Integration
  • Embedding Content — 10:02
  • PDF Annotation — 10:05
  • Import Headings — 4:19
Structural & Visual Mastery
  • Grouping & Icons — 18:16
  • Move & Fold Nodes — 10:00
  • Advanced Styling — 17:31
Output & Sharing
  • Export & Share — 9:31
Updates
  • v26.03.01: Submaps & Layouts — 8:30
  • v26.03.08: Tasks & Export — 6:51
  • v26.03.15: Embed Toggle — 3:56
Live Q&A Recordings
  • Two recordings, a total of 2.5 hours.
Included Course 3: Slideshow v4
Total Runtime: ~1 hour 16 minutes
Turn your visual notes, sketches, and whiteboards into interactive, high-impact presentations without leaving Obsidian.
With Slideshow v4 you can:
  • Present directly inside Obsidian in windowed or full-screen mode
  • Build frame-based decks with non-destructive Marker Frames or fluid line-based visual paths
  • Stagger ideas with progressive reveals, fades, and camera zooms
  • Run dual-monitor presentations with Markdown speaker notes using Presenter View or iPad Sidecar
  • Export high-resolution, print-ready PDF decks with custom aspect ratios
Core Walkthrough & Lessons
00: Course Guide 02:57 Slideshow v4 architecture and feature overview
01: Your First Slideshow 06:39 Script installation, frame tools, and launch shortcuts
02: Building Frame Presentations 13:35 Marker frames, slide naming, aspect ratio fitting, and hiding slides
03: Building Line Presentations 08:27 Point-pair coordinate paths, line resequencing, and canvas hiding
04: Managing Slides in the Side Panel 07:19 Visual slide sorter, custom aspect ratios, and floating windows
05: Animations & Progressive Reveals 05:57 Step-by-step element reveals, delays, and animation sequencing
06-07: Speaker Notes & Presenter View 12:40 Markdown presenter notes, teleprompter / Sidecar dual-monitor mode, laser pointer
08: Converting Presentation Types 07:23 Switching between line and frame decks, rapid drafting workflows
09: Exporting & Presentation Quality 06:43 PDF printing, DPI scaling, Printable Layout Wizard, Markdown images
10: Power-User Workflow & Settings 04:23 Camera transition speeds, zoom factors, and UI auto-fade
Part of the Bigger Picture
Excalidraw Mastery focuses on the tool.
Visual Thinking Workshop focuses on workflow.
Sketch Your Life focuses on better thinking.
See the Ecosystem
Ready to Go Further?
See Plans & Join
