Obsidian-Excalidraw Document Properties
Excalidraw document properties control Excalidraw’s behavior at a file level. These properties override plugin settings for the document. Properties offer some very powerful file level customization opportunities or even, like in the case of “onload-script” scripted automation.
Property Type Description Example
excalidraw-autoexport text Override autoexport settings for this file. Valid values are: none | both | png | svg
png
excalidraw-border-color text This key applies to Markdown Embeds. You can control the appearance of the embedded markdown file on a file by file bases by adding the this frontmatter key to your markdown document. Valid values are: css-color-name|#HEXcolor|any-other-html-standard-format SteelBlue
excalidraw-css text This key applies to Markdown Embeds. You can control the appearance of the embedded markdown file on a file by file bases by adding the this front matter keys to your markdown document. Valid values are: “css-filename|css snippet” “”
excalidraw-default-mode text Specifies how Excalidraw should open by default. Valid values are: view|zen view
excalidraw-embeddable-theme text Override embeddable’s theme plugin-settings for this file. ‘auto’ will match the Excalidraw theme, ‘default’ will match the Obsidian theme. Valid values are: dark | light | auto | default
auto
excalidraw-export-dark checkbox If this key is present it will override the default excalidraw embed and export setting. true == Dark mode / false == light mode true
excalidraw-export-embed-scene checkbox If this key is present it will override the default excalidraw embed and export setting. false
excalidraw-export-internal-links checkbox Default value, if not set, is true. Set to false to prevent internal links from being exported to SVG images and PDFs. false
excalidraw-export-padding number If this key is present it will override the default excalidraw embed and export setting. This only affects both SVG and PNG export. Specify the export padding for the image. 5
excalidraw-export-pngscale number If this key is present it will override the default excalidraw embed and export setting. This only affects export to PNG. Specify the export scale for the image. The typical range is between 0.5 and 5, but you can experiment with other values as well. 1
excalidraw-export-transparent checkbox If this key is present it will override the default excalidraw embed and export setting. true == Transparent / false == with background true
excalidraw-font text This key applies to Markdown Embeds. You can control the appearance of the embedded markdown file on a file by file bases by adding the this frontmatter key to your markdown document. Valid values are: Virgil|Cascadia|font_file_name.extension Virgil
excalidraw-font-color text This key applies to Markdown Embeds. You can control the appearance of the embedded markdown file on a file by file bases by adding the this frontmatter key to your markdown document. Valid values are: css-color-name|#HEXcolor|any-other-html-standard-format SteelBlue
excalidraw-link-brackets checkbox Set to true, if you want to display [[square brackets]] around the links in Text Elements true
excalidraw-link-prefix text Set custom prefix to denote text element containing a valid internal link. Set to empty string if you do not want to show a prefix “:round_pushpin:”
excalidraw-linkbutton-opacity number The opacity of the blue link button in the top right of the element overriding the respective setting in plugin settings. Valid values are between 0 and 1, where 0 means the button is transparent. 0.5
excalidraw-mask checkbox If this key is present the drawing will be handled as a mask to crop an image. true
excalidraw-onload-script text The value of this field will be executed as javascript code using the Script Engine environment. Use this to initiate custom actions or logic when loading your drawing. “new Notice(Hello World!\n\nFile: ${ea.targetView.file.basename});”
excalidraw-open-md checkbox If this key is present the file will be opened as a markdown file in the editor true
excalidraw-embed-md checkbox When set to true, embedding the drawing into a markdown note will render the “back of the note” (its markdown content) instead of rendering it as an image.
If you want to always display the drawing as an image, even when excalidraw-embed-md is enabled, use the special embed syntax: ![[drawing#^as-image]]. Here, as-image is a phantom block reference that forces image rendering.
true
excalidraw-plugin text Denotes an excalidraw file. If key is not present, the file will not be recognized as an Excalidraw file. Valid values are ‘parsed’ and ‘raw’ parsed
excalidraw-url-prefix text Set custom prefix to denote text element containing a valid external link. Set to empty string if you do not want to show a prefix “:globe_with_meridians:”
