Hybrid markdown-excalidraw note template
This is an advanced version of the template Nicole uses in her video:
This template assumes you have Templater installed and configured to run on new file creation. The template will:
  • Default to opening in markdown mode, but you can switch to Excalidraw view using the command palette action Excalidraw: Toggle between Excalidraw and Markdown mode.
  • Auto-export an SVG with the same file-name when you save the file in Excalidraw mode.
  • Create an initial small dummy SVG file so that when you rename your new “Untitled” note, the “Untitled.svg” will also be renamed.
  • Prevent Templater from reprocessing the template when synced across devices, which can otherwise cause issues. If you’re syncing your Vault to multiple devices (I use 6), Templater will incorrectly treat synced files as new and run the template again, rendering it unusable.
This template also leverages the excalidraw-embed-md frontmatter property. When this property is set to true, embedding the Excalidraw file into another markdown note will display the markdown content (the “back of the note”) instead of rendering the drawing as an image. This is useful if you want to show the text and metadata of your drawing directly in other notes.
If you prefer to always display the drawing as an image—even when excalidraw-embed-md is enabled—you can use the special embed syntax:
Here, as-image is a phantom block reference that forces image rendering, overriding the markdown embed behavior.
How to use the snippet:
  1. Copy the markdown block below to an empty note. Make sure the note doesn’t have any document properties, or switch the Obsidian Editor to Properties in Source mode to ensure this in Obsidian Settings.
  2. Replace the escaped ticks ( \ ) by removing the 6 backslashes — 3 before json and 3 before the second %%.
  3. For more details about the “Cannibalization” at the beginning of the file, read: Templater Cannibalizes Templates with Obsidian Sync.
excalidraw-plugin: parsed
excalidraw-open-md: true
excalidraw-embed-md: true
excalidraw-autoexport: svg
  const PATH = app.plugins.plugins["templater-obsidian"].settings.templates_folder;
  if(tp.file.folder(true) === PATH) throw(new Error("Cannibalization"));
# [[<% tp.file.title%>]]
  const path = (tp.file.folder() === "" ? "" : `${tp.file.folder(true)}/`) + `${tp.file.title}.svg`;
  if(!app.vault.getAbstractFileByPath(path)) {
	app.vault.create(path, `<svg version="1.1" xmlns="http://www.w3.org/2000/svg" width="0" height="0"></svg>`);
# Excalidraw Data
## Text Elements
## Drawing
\`\`\`json
{"type":"excalidraw","version":2,"source":"","elements":[],"appState":{}}
