Excalidraw 2.29.0 - Let your agent draw for you!
  • Excalidraw CLI for AI agents. Local AI agents can create, edit, inspect, and export drawings, and run trusted scripts. Requires Obsidian 1.12.2+ with CLI enabled. Select Excalidraw: Show CLI and agent instructions to get started. #2988
  • Better image attachments. Pasted and dropped images now follow Obsidian attachment rules, including compatible attachment-management plugins. #2964
New from Excalidraw.com
  • Wrap or unwrap with W. Put text inside a shape, detach labels, or wrap selected elements in a frame. Press W again to reverse the action. #12264
  • Select overlapping elements. Alt-click to cycle through stacked objects. #12237
  • Smarter duplication. Duplicated numbered labels and list items automatically advance their numbering. You can also Alt-drag to duplicate text while editing it. #12189 #12219
  • Better cropping and resizing. Shift maintains image crop proportions, Alt crops from the center, and double-clicking a crop handle restores an edge. Corner resizing for text is more intuitive. #12260 #12262
  • Improved frames. Edge-aligned elements are included correctly, clipping is more consistent, and cutting a frame includes its contents (deleting a frame still leaves them behind). #12270
  • Google Drive videos start playing when you activate their embeds. #12246
  • Text undo/redo. Editing after undo or redo no longer restores outdated text, and closing an unchanged editor preserves redo history. #2976
  • Markdown embeds. Fixed blank or interrupted drawing embeds, nested and self-referencing drawing images, and back-of-the-note embeds showing the full drawing instead of the linked section. #2953 #2979 #2931
  • Grouped links. Ctrl/Cmd-click selects the intended group member first; a second click follows that element’s link. #2989
  • LaTeX in popouts. Fixed cursor placement and keyboard selection when editing formulas in a separate window. #2970
  • Middle-mouse panning over a text editor no longer ends text editing or multiplies the movement. #12244
Excalidraw Automate
  • Scripts can use the new CLI through ea.executeCLI() and create drawings at an exact path with ea.create().
Thanks lot Zsolt for bringing us Excalidraw CLI.
I know we should keep in mind “Visual First”. There are so many texts here. :grinning_face: But I believe it’s not a bad start and will have chance to improve summarization skills in the future.
Did you have your agent work from a prior generated image, or asked it to create the summary directly in Excaliraw?
I asked Claude Code CLI (Opus 5.5 @medium) to create a summary from pure Markdown to Hybrid note.
It looks really good​:+1:
This has changed the game, after this release, I have created 653 excalidraw drawings with Claude Code into my vault. Those are mostly paddling related route maps from Scandinavia and Canada. Claude Code is amazing with this, especially Opus 5.5 with medium effort.
Just an example, Norway paddling routes (in Finnish):
