Excalidraw 2.22.1
  • Added a command palette action to switch all currently open Excalidraw drawings to view mode. (This feature was inspired by our 15 minute virtual coffee chat with @SGrimm)
    • While this temporary mode is enabled, any Excalidraw drawing opened afterward will also open in view mode.
    • This is useful when presenting multiple drawings and you want to avoid accidentally moving elements, and when you don’t want the tools to be in the way.
  • Added an optional phone-only layout setting to push Excalidraw’s footer controls above the system navigation bar on some Android devices #2688, #2652, #798
    • Look for "“Extra bottom padding for phone controls” in the plugin settings.
  • invisible cursor color in color picker, mermaid chat, in text elements in dark mode #2739
  • image sizing issue when embedding image type “SVG Image” to markdown
  • copying a nested image fragment in Excalidraw and pasting to markdown lost the image block reference
  • modifier keys conflicted with Excalidraw alt-select (lasso) behavior
