Capture Note v260629
v260629
For more info about the capture note script read: Capture Note Script
1. Notes in same folder
New notes can now be saved to the same folder (or subfolder) of the current note. FYI: @Kai
Click the folder icon in the path row to toggle between
2. Improved flow for new note types
If the note type you want to create does not exist in the configuration you can now create a new note type on the fly
2.a. Click the plus icon in the Note Type row to create the note type
2.b. To help make the process smoother, you can configure a generic base template that the new note type will inherit. Setting this will speed up the process of creating a new note type in the heat of the note taking moment. You can configure this on the Configuration Panel (click the cog in the bottom)
3. Version number
The script version number is now visible in the top right corner
4. Improved reference link displays context
Minor improvement involving reference links. #^group=${blockID} is used in cross reference links. The benefit is, if you hover this link, the referenced element, and if the element is grouped with other elements, then those elements as well are visible in the hover preview. This is great when capturing actions in a mind map. If you group the node with the action with its childe nodes, when you hover the action in a list such as created by the Tasks plugin, you will immediately see the required context for the action.
