K-Plex 0.1.3 - Wander & Wonder
This release brings a new way to explore your knowledge graph, smoother navigation, better Sidecar integration, and a collection of fixes that make K-Plex more reliable and enjoyable to use.
:sparkles: What’s New
:person_walking: Wander — Explore Your Knowledge Graph
Introducing Wander, a new way to explore your knowledge graph.
Instead of deciding where to go next, let K-Plex take you on a journey through connected notes. Discover connections, revisit forgotten ideas, and see where your knowledge leads you.
Wander includes dedicated controls and smooth transitions as you move between notes.
:link: Smarter Sidecar Integration
Working with K-Plex alongside your notes is now more intuitive.
  • Attach an existing adjacent pane as your Sidecar using the new directional controls.
  • Open the central K-Plex note in your Sidecar, or bring the Sidecar’s note into the center of K-Plex.
  • Switching between notes no longer causes duplicate Sidecar openings.
  • Rapid navigation now reliably follows your latest selection rather than jumping back to an earlier note.
  • Improved Sidecar layout and behavior when reopening panels.
:bullseye: Smoother Navigation and Better Automatic Fitting
K-Plex now does a better job keeping your graph in view as you explore.
  • Smoother visual transitions when navigating between nodes.
  • The central node stays centered as surrounding connections appear during background indexing.
  • Manual zooming and panning take priority over automatic fitting.
  • Embedded Excalidraw drawings automatically adjust to their available space when appropriate.
:artist_palette: More Control Over Your Workspace
The graph background context menu now provides quick access to useful actions:
  • Open K-Plex settings.
  • Switch to Zen or full-screen mode.
  • Customize the graph background color.
  • Report a bug.
Tooltips have also been refined for better readability, including controls near the bottom of the screen.
:hammer_and_wrench: Fixes and Improvements
More Reliable Note and Relationship Management
  • Note deletion is safer: K-Plex cleans up configured ontology references while leaving unrelated properties and ordinary Markdown links untouched unless explicitly requested.
  • Renamed notes stay connected: Renaming a note now correctly updates its identity and labels in the graph without leaving stale references.
  • Correct relationship arrows: Explicit ontology relationships retain their intended direction, even when ordinary links point the other way.
  • Clearer Hide Connection behavior: Dialogs now explain which perspective will hide a relationship, while preserving the original links.
  • Reliable style editing: Saving or deleting node and relationship styles now completes correctly without getting stuck waiting for unrelated background updates.
Better Mobile Experience
  • Reopening K-Plex in the mobile sidebar now follows the latest relevant note.
  • Double-tapping the central node opens its note in the main workspace.
  • Improved readability of stacked layout controls on smaller screens.
Better Privacy and Image Handling
A new Allow remote node images setting gives you control over whether K-Plex loads images from external websites.
Remote image loading is disabled by default. Images stored locally in your vault continue to work without requiring this permission.
Improved Responsiveness and Stability
  • Reduced redundant file reads during startup and background indexing.
  • Improved consistency when navigation and indexing happen simultaneously.
  • Fixed menu positioning so toolbar menus open beside the correct controls.
  • Improved handling of graph views and menus when moving between windows.
  • Improved indexing status information, including cleaner callouts without overlapping tooltips.
:heart: Thank You!
K-Plex is evolving quickly, and your feedback, bug reports, and ideas are helping shape its direction.
If you encounter an issue, use Report a bug from K-Plex to collect diagnostic information that can help me investigate.
If you enjoy K-Plex, please consider supporting its development:
Happy exploring!
Zsolt
I gave “Wanderer” a try in my Vault—which, truth be told, isn’t structured very well at all—and therefore without any great expectations. I’m genuinely amazed! It really stimulates the visual thinking process; that might sound technical, but for me, it was actually a lot of fun—a truly engaging emotional experience. It immediately leaves you wanting more!
Some use cases also sprang to mind, such as:
a) Learning paths: anticipating and predicting the content of a card based solely on its title, testing yourself before the card is actually revealed.
b) Filtering the collection of cards based on a time criterion—turning it into a monthly retrospective, much like flipping through a photo album.
A very playful and meaningful feature - thanks a lot @Zsolt !
